ANy pics or where anyone mounted the Outlet kit on the SM-T? Where the heck do you mount it and why is it so dang small?!
Does the universal plug charge an iphone?
Thanks, JimmyDean
This is how i installed it
This is where the ACC1 & ACC2 connection is located(in the service hatch behind the head light).
sweet, Thanks Sparky!
So when you peeled off the fairing could you haqve done either the left or right side? Also what size bit did you drill it with? Lastly when you hooked up the wires are the ACC1 & 2 ready and open for insertion or did you have to splice them?
There are 2 ACC1 wires and 2 ACC2 wires. ACC1 wires are live all the time, ACC2 wires are live only when the ignition is on. There should be small stickers on the wires to identify them. They all have sheathed female spade connectors attached.
I used a large shaped grinding stone no drill, but you can also use a tapperd drill.
To connect the socket to the acc1 or 2 you only have to use male spade connectors
