1 - 4 of 4 Posts
As above folks ... just trying to find a live feed on my 2013 990 Adventure so that i can wire up my LED spots to come on when the ignition is on and engine running ...
Anyone know of a spare around the dash area :D
There are two feeds, ACC 1 and 2. One is switched from the ignition, ? can't remember which. I used a 40amp car relay and ran two 40amp gauge wires from battery (2.5mm2 will be fine), so I used the ACC which operates from ignition to switch relay and used the feed for my spots and heated grips. Ive been meaning to install a small fuse panel, 4 or 6 blade.
1 - 4 of 4 Posts
