Hi there chaps, my speedo has decided not to work, how can i check the sensor pick up is working? (Magnet is okay in the wheel) the cable running up to the speedo head looks fine, what else could be causing the fault, When i press the button on the speedo head it does trnn on so the battery and speed head seem to be okay
Disconnect the sensor at the plug behind the headlight. Get a little bit of wire and keep shorting the contacts in the connector together to make a pulse. Speedo should read.
Stupid question, but the bike doesnt have to be running does it?
Okay did all that and found the pick/sensor is knackerd, how much is a new one and where sell them? 250EXC 09
