1 - 4 of 4 Posts
OK going through the process of setting up and overhauling the suspension, what weight is this spring please.
The picture is of the later progressive springs which starts at 63N/mm, then hardens up through 66N/mm to 69N/mm as it's compressed.
The manual seems to be showing the old linear single rated springs.
give KTech a call, they will tell you what spring rate you need over the phone and be able to supply correct spring.
1 - 4 of 4 Posts
