STIC, It's Hot!
Of those testing the STIC metering block and the carburetors set up by STIC Headquarters; these tests are occurring worldwide on a continuous basis. The tester’s opinions are un-biased and uncensored, their positive reports continue to offer proof that the STIC is unique and there is hard dyno reports along with live field reports that prove the STIC methodology is the real deal. Thanks to following for their efforts to explore the STIC’s features and possibilities: James JD Jetting, MOG, Derek (Harris performance), TOKYO Off-Road, RC250, Sam Evans, Rado (Dirt-n-Iron), Sidecarbod, Steveman, sand300, and many others, thank you. The recent MOG dyno testing is extensive and thorough. This conclusively proves the instant lifting of the front wheel from idle to points in between wide open, the STIC’s improvement in torque and improved acceleration is real.
Re: How good is the STIC?
moggy mx [email protected]
Sun 10/4/2020 11:23 AM
To:
[email protected]
Hi George, this my impressions from doing the dyno work.
The thing I have found with both stock Keihin and the stock Mikuni carb is that they will not adjust to be good in every throttle range. They are so compromised that you are always giving up in one area to gain another, on top of that, I have only ever seen 1 Mikuni carb that had good AFR are across the whole range
My findings with a STIC on multiple applications are, once you understand the STIC system you can quickly get it to have a good AFR across all throttle ranges. Moving onto the STIC power, you can literally dial in in as much quarter throttle power as you could ever desire, we have backed it down slightly to control the power.
In jetting the STIC a little bit richer, I have found that you can get much more power in the quarter and half throttle range, more peak, and more over-rev. The STIC fueling is as good as a fuel injection system. The STIC’s strong power is evident on every bike with better part throttle, full throttle peak, and better over-rev. I cannot see a downside to the STIC other than the rider may not have the ability to make use of STIC’s acceleration and power.
In all the modifications I have done in past +20 years of playing with engines, and fuel systems, nothing has ever worked as well as the STIC, it is consistent across all brands, in fact, the competition is not even close to what the STIC does. The STIC is truly a unique product, I am pleased that I came across it when Derek Harris sent me one to test.
Kind regards Marcus
2020 TC 250 dynos using stic ,pc pipe , dep shorty , PV springs
Rado (Dirt-n-Iron) new video depicting changing the rear sprocket from a #50 to a #48 to lessen the STIC’s violent acceleration.
To:
[email protected]
Kind regards Marcus
