I'm converting my 690 Enduro to a supermoto. I've got most of the parts I need now. Nice little project to work on.
Can you expand on that at all?
Ah, OK, that makes more sense, thanks.Thats not how it works. The steering stem is pressed into the bottom yoke, it will come out but its tight. When you remove the top yoke, the stem and bottom yoke, plus the part of the bottom bearing, will drop out downwards.
It's pretty straight forward once you get into it.
Why do you ask - what are you hoping to achieve?Is it possible to leave the fork tube in the frame with the bearings in place and just replace the top and bottom parts of the triple clamps?
I refering to part 17.
Whilst there are differences, the way it is fitted etc will be the same - i.e, the stem can't be left in the frame minus the clamps. Thats my interpretation.This is the fiche for a 2020 350 EXCF. there looks to be a fundamental difference in the design of the triple and the way the bottom yoke connects unless I'm missing something?
