Ok,
A bit of a long shot, I've decided I'd rather have a second set of enduro wheels rather than the SM wheels.
They were off a 690 SM I have the front spacers for that if needed, will fit the 690 Enduro or R rear just fits with the standard spacer, front you need to use the enduro spacers.
I have the larger front disk and spacer for the SM as well.
Don't want to sell them but if you happen to want to swap let me know, if not I'll just use the hubs and get them re built.
In good condition has rear tyre with plenty of life, front is about done but still legal.
Are they wire wheels? What colour rims?
I'll grab some pictures tonight, got them on the bike at the moment, wire wheels, black rims, standard 690 SM I'm 99% sure, I think there may be a tiny chip in the rear rim from the first time I swapped them over before I worked out how to clear the rear brake nicely :D I'm looking for a set of enduro wheels that will fit the 690 don't mind having a thinner rear rim like the EXC's have, in fact that would be a bonus.
Neither EXC/SX nor 625/640/660 LC4 rear wheels will fit. The 690 has a wider hub and different cush drive sprocket carrier. The 950/990 hubs are wider still.
Discussion Starter · #6 ·
Beat me to it :D yes it wouldn't work but thanks for the offer! fyi you can get a converter now to run the LC4 rears on the 690 Rear Wheel Adaptor Kit - Products - KTM690 Enduro Rally Specialists - Rally-Raid Products but I didn't want to do that route, just wanted to do a direct swap. I know it's a bit of a long shot, think I'll end up getting new spokes and rims for the existing hubs.
Can EXC hubs (Talon) be made to fit with spacers?
its not relevant now but 660 smc wheel can be made to fit a 690 smc ive done it but its a days work faffing around measuring things and turning spacers ,just thought i,d chip in my two penneth , i know i'll get me coat
