1 - 11 of 11 Posts
right my stator burnt out thus resulting in getting no spark.
so i replaced the stator, the plug, the ignition coil, the ht cap and lead and yet still i have no spark, so this only leaves the problem to be the CDI right?
i am going to order one on friday and hope this solves the problem but what i wanted to know is:
i tried the CDI off my mates rmz 250 and i know its not designed to run with my sx 125 but should i of least of got a spark when i connected his CDI to my bike or will that not work at all?
if i replace the CDI and yet i still have no spark i am stumped of what else it can be as i have replaced everything electrical to produce the spark.
any one who can shed so light on this i will owe you a beer!
I'd be checking the wiring and the earthing before i buy a cdi.
ive stripped all the wiring off the bike n checked for breaks in the wires and cleaned up all the earth connections and checked the continuity and all is good, my head is pretty burnt out with this!
yeah getting a voltage through the wires to the coil but as soon as i connect them to the coil i get nothing :/ by timing pick you do you mean the timing on the stator plate?
Discussion Starter · #7 ·
Not familiar with the engine, some motors have pulse coils in the stator, some electromagnetic pickups that speak to ECU….If you’re getting power to the coil but as soon as a draw is present it shuts off…that’s the problem….timed shut off to the coil gives you the spark….
any chance you could dumb that down a bit for me ha!
and suggest how i could try n sort it, im not the best at electronics.
cheers :)
1 - 11 of 11 Posts
