1 - 20 of 31 Posts
Conked out just after pulling of the motorway - both times it's died on a slip road showing 4 bars. Luckily only a couple of km from home this time.
Not much pisses you off more. And not much makes you feel quite as much of a cunt as filling a bike up from a can on the side of the road as your neighbours drive past. I feel like going around knocking on doors and showing them all a film of the fuel gauge while trying to start the cunt.
KTMs need to come with a sign you can put up while fucking about with it that says, "The bike is the cunt! Not me!"
Mind you, I'm the cunt for buying it.
Out of fuel on 4 bars sounds like you only have one tap open.
Didn't you sand the sides of the fuel level float down?
One of the first jobs I did on my 1190 as often it would sit at full for ages and then suddenly drop to 2 bars. Since sanding it's been faultless.
Running a 2020 1290 SAS. Went down onto one bar in a very progressive manner and then started flashing low fuel warning. Rode another 20 miles and still only got 20L in tank so seems OK. Hopefully it will stay like that.
Discussion Starter · #5 · (Edited)
It's the gauge.
The one time it happened before was when it was still a spring chicken about 5 years ago. Got recovered to a KTM dealer. I asked them to chuck in a litre of fuel and see what happens. Lots of sucking through teeth and, "Nah, it'll be a bit more complicated than that mate." Refused to drop some fuel in, so I left it with them
Get a call a couple of days later. "It ran out of fuel. We've had to get some new software from KTM. Downloaded. Rebooted. Blah. Blah. Bullshit. Bullshit. It now works." All on the guarantee, so who cares.
No bother until today. I guess it's starting to get a bit furry in there. Fucker hasn't budged with a full tank and a good kicking. Maybe it's time for more new 'software'.
40139
It's the plastic float swelling that causes it, but then if it is this it would only jam when showing full.
Worth checking though as it's a pretty basic level sensor.
I still reset the trip on mine at each fill up, old habits die hard.. but I am relying more and more on that gauge.
There is a new fuel level sensor part number that came out on the 2018s...
60307080100
It's allegedly a new design that won't stick.
Previous part number is 60307080000.
But in the last couple of months there has been a further update New number 60307080200.
This is a much better gauge , just make sure you get the latest version. Fit yourself takes 15 minutes at most and be sure it is done well . Will cost around £90 here in the UK
Discussion Starter · #11 ·
60307080100
Thanks. On the list for the coming winter when it's due its biannual strip-down.
Discussion Starter · #12 · (Edited)
My spider senses were tingling on the way home because I'm pretty sure it was showing half a tank when I left home and I was considering topping up the tank but it said it had a range of 230km, so I figured I would fill up after my meeting about 80km away, but didn't because of the gauge and it then konked out after riding about 170-180 km due to also running a couple or errands after the meeting. And most of those km's were quite fast on motorways. I've now put a sticker above the gauge that says, "Bullshit meter"
Discussion Starter · #13 ·
Looks like the sensor's electrics are fried. Took out the sensor and the float's moving freely. Hooked it up and the bike's still showing 4 bars whether I turn it upside down or right way up with the float at the top or the bottom. Bike shows a failure and flashing fuel gauge when I disconnect it, so I guess the bike's brain is okay. Tried disconncting and connecting the battery, but made no difference. So I guess it's a new, latest and greatest sensor. Arse.
Are the conductor tracks clean in the sensor?
I could be wrong but I don't think there are "electronics" in the sensor. Just a resistance strip with contact pads that are shorted by the float.
Pop the bottom cap off and let the float slide out so you can inspect it.
Discussion Starter · #15 ·
All looks clean in there. Gave it a squirt of sensor cleaner just in case, and no change. I think it's broke.
Discussion Starter · #16 ·
Just saw this from an earlier thread...
"You did ride it for 10 miles for the computer to reset? "
Maybe take it for a spin once the effects of the post-fettling-failure-anti-depression dry martini has worn off
Just checked the wiring diagram and it is shown as being a 2 wire device, and it's symbol is of a variable resistor. I think in actuality it's just a series of fixed resistors along a strip, and the float connects across them as it moves.
What worries me is if it really is just this then it's unlikely to have failed in the way you've described.
I think if you did plan on replacing it I would first test the existing one to be sure it really is the problem.
Once the sensor is off the bike you should be able to test it at the connector with an ohm meter, and tip it over to make the level shift, which should result in the resistance changing in steps.
I know the fucking thing should work, I had to drive with a can of fuel for a mate cost his fuel gauge was telling porkies. My point is how did we survive before fuel gauges on bikes, we pulled the fuel cap and sloshed what was in the tank and listened.
I heard an entire steel plant shut down recently due to a cyber attack...FFS, 40 years ago the steel mills ran just fine without a computer.
Discussion Starter · #19 ·
It's a tricky bugger, because it sloshes even after it stops. The first time it happened 5 years ago the first thing I did was have a listen at the open fuel cap, shook the bike, and heard sloshing. So figured it was something else. It got recovered by a truck with a ramp that we pushed it up onto and strapped it down. After getting it off the truck at the dealer, I thought I'd give it a try, and it ran for about 20 seconds before dying. I guess because some of the last remaining fuel sloshed over to the outlet while pushing it on and off the ramp and during the drive. This is what had me then thinking it had run out of petrol and asked the melodramatic dealer to chuck a litre of fuel in to see what would happen.
They claimed it was a software issue back then. I had no reason to doubt them, but I kind of have since because I've not seen it on any forums. But maybe they were right and it's come back. I'll take it out tomorrow and see if it re-sets after 10 miles.
Zero your trip when you refuel. Simples.
And don’t fill up with diesel (even if it is fucking ‘Super’ diesel with a red nozzle). That’ll make your bike stop too. And look an even bigger cunt than if you simply ran out of fuel with a dodgy-fuel-guage-excuse. (Don’t ask me how I know)....
1 - 20 of 31 Posts
