Sounds like all you need is to adjust the cable slack? Dont do it too tight or you might find it gives you problems off road.
Two places to do this.
1.
Up at the throttle on the handle bars where the cables come outta the throttle housing - there an adjuster on each
2.
In the air box with the air filter out.
Either one will do, but if you need to adjust it a lot you may need to start at the airbox end.
3.
Get a 990 - you'll have opposite problem - it squirts the juice just becasue you thought about moving the throttle :D
