1 - 10 of 10 Posts
You have to re-set the throttle cables on the carb.
there's an adjuster just down the throttle cable from the twist grip. it's under a rubber sleeve. Just adjust it to where you want. But remember you must have a little bit of play. Was one of the first things I did when I got my 990sm:cool:
Nope, only one. The way to make sure it's not too tight is to adjust it then turn the steering from side to side. If the revs increase, back off the adjuster. Job done.
1 - 10 of 10 Posts
