hi, my throttle is sticking on right lock, cables are free from anything i can see. will a new alloy tube be worth trying ?
thanks Rob
If its only sticking on right lock it will be the cables. Nothing else is affected by lock.
hi Kev , just had the tank off "again" to check freedom and the cables are nice and free . as you say it is the cables , but they only move slightly when right turning but still jams up. any other suggestions ?
thanks Rob
I've just fitted new cables, and had same on right lock, slackened the return cable off a couple of threads and its fine now
