Ok so I have fumbled my way through fitting the vapour and now have indicator warning lamps (for left and right) and high beam warning light (this was easy as bike came with that already!). Fitted the temp sensor and tach sensor too and
all thats left to do is the speedo sensor which seems to be pretty straight forward the one thing I am struggling with is the power feed as I am not sure which wire to tap into. I want the vapour to turn on as soon as I start the engine so would that mean direct to battery? If so which colour wire is this at the front of the bike and do I connect the black to an earth?
Finally do I need to put a fuse in line or will the fuse at batter protect the circuit? I tried playing around with multi meter to test some wires for a 12v feed but managed to blow a fuse!
