Hi, has anyone fitted the Vapor Tech Clocks, and can the existing wiring be used, ie the plugs etc??? :scooter:
If you mean existing old vapour wires then yes they should work fine. Although I replace all mine cos it's a doddle!!
Sent from my iPhone thingy using Tapatalk
Its not plug and play with KTM speedo connectors if thats what you mean.
Yea, its a pity it wasn't just a case of plug and play, I got it all wired up, no probs, except the RPM signal. There's bound to be already a signal wire at the headstock that I can tap into to get the RPM working, does anyone know which wire and colour it is? Thanks Rosco
I connect mine to the terminal on the coil.
