Guys, Chain and sprocket are knackered on my 530EXC-R so just want to know what you would recommend, sizes, make, where to get them? Steel rear?
I ride green laneing and practice enduro, just starting so I'm no expert....
Cheers,
Renthal 520 o'ring very good chain never had any problems, but any good o or x ring should be fine
supersprox stealth are bombproof; my last one did over 6,000 miles. I run a 52th rear and a 15th front. this saves wear on the chain slider................. i know it says on the clutch saver not to go over 14th but a 15th fits and is ok. chains? any o-ring is fine, just clean and lube after each ride.
