13481 - 13500 of 13504 Posts
I moved the goalposts on freedom a bit and went out on mine today.
Obviously being on a bike there's no social distancing needed, if someone is closer than 2m, well, we've got issues.
2020-05-12_10-24-34 by Steve Weeks, on Flickr
How was it then... bloody marvellous.
I was impressed by how much of a difference the shock made... Just handles and turns a chunk better, sometimes it's only when you remove something you realise how much of a difference things make.
Power, performance, whatever you think of it as, just brilliant braaaap, braaaap, through the box, smooth silky gear changes, dropping it down into a turn on the slipper clutch, just excellent.
Turn in, was just great, it's SO fast at tipping in and out of corners, i can't do it justice of course, but i try my best, honest :)
There were 2 things that were not so perfect,
1. Startup MTC error lol....
2. Lost an exhaust bracket bolt...
Neither anything major and the bolt is replaced, on re-start no error message of course.
Top bit of fun though.
Changed springs and oil in my 4CS forks. Read the instructions... did the job again but properly. Read instructions again... Did the job properly and correct. Effort.
Fitted a Scotoiler to the 1290 SAR. Bit of a faff removing the tank but theres a cracking video on Youtube explaining the steps. Pretty straightforward from that point. Not something I would have tackled before lockdown but glad I did. Going to install auxiliary lights whilst the tank is off (if I can work out the switch wiring).
Not sure you would need to remove tank as it's a bit off a pain in the arse for either as there are acc1 and acc2 under the seat for the scottoiler and in the light for the auxiliary lights
Sent from my SM-G973F using Tapatalk
I still do. I've been using them for 20 years and have never tried an electric one. I doubt that i will change now as long as this one keeps working.
If I were starting now I would probably go to the electric.
Yes its vacuum, had it a while(never got round to fitting it to my 1050). Would struggle to hide the wiring for the lights around the tank so two birds with one stone and all that.
140-150 miles on the 690 today and had a blast out there. Bike and me were both on great form.
Had to laugh on the b4494 as I caught 5 sports bikes up and sat behind them thinking "why are we going so slow"
I was sooooo tempted to be childish and blow past them, but now isn't really the right time for things like that.
Gear changes are deffo better with lever down though.
A million dead flies covered the bike I must admit, 20 minutes work there!!!
Often it's just the back wheel and chain that look dirty (plus the fly splats all over the front).
For my 990 (with no centre stand) I can't be arsed to set up the ABBA stand just for a chain & rear wheel clean, and I don't trust my shitty paddock stand as I've almost dropped it once on that... so I decided to make up this swing arm lift kit...
Simple to do..
Lock the front brake with re-usable cable ties.
Side stand in a chock that I "milled out" on my pillar drill. Had fun doing that, felt like a proper machinist.. sort of..
That stopped the bike sliding across the floor when I lifted it from the other side.
Finally a prop under the swing arm made to size to allow the tyre to clear, with a bit of old wet suit to protect the paint work. Just lift the rear against the side stand and then give that a kick inwards to take up the slack.
It's quick to do & surprisingly stable.
Can then clean the rim and give the chain and good oiling and towel down to leave it looking clean and shiny.
I'm ready now for a bit of ride tomorrow, off to Bude because the Mrs wants to ride there. :)
Simple to do..
Neat. I would ditch the reuseable cable ties though as they are not that strong and easily break. I would use a cut down ratchet strap (what i use when a bike is in the van to keep it steady)
