If I cleared my garage out that field would be full..
Sweeet
It feels so light compared to the 690Sweeet
£1040 posted. You can buy a service kit for £20 (oil and cleaner) but it comes ready to use and the cleaning stuff is exactly the same as you'd use for K&Ns so you can get it at bike shops or moto factors.How much did all that set up cost? Looks ace. Have a Gen 2 SDR with full Akrapovic system - would certainly be looking to do this.
Thanks that really helpful, could be the next step for my bike.£1040 posted. You can buy a service kit for £20 (oil and cleaner) but it comes ready to use and the cleaning stuff is exactly the same as you'd use for K&Ns so you can get it at bike shops or moto factors.
If your gen 2 has a charcoal canister you need to get rid of that as well or you'll struggle to fit the PCV under the seat. Don't think it affects the ECU to just get rid of it.
Tip, it comes with a stainless plate which is cable tied behind the headstock and is supposed to hold the air intakes where they would have fitted into the stock airbox. Don't bother trying to use it or refit the intakes. It's a needless fiddle, they don't fit very well and they makes absolutely no difference to how the airbox breathes. Probably impedes airflow if anything. And you can't see that anything's missing without them.
Chap from P3 said I had bought the last one he had in stock and it will take a couple of weeks for his next order to come through. So if you want one I'd order as soon as poss. Fella's good as gold to deal with.
Stunning bit of kit by the looks of it. More oomph?Fitted DNA stage 3 airbox and a pre-programmed PCV from P3 Tuning today. (P3 are no longer dealing with Rottweiler, they are now importers for DNA, which is great news because they are fantastic bits of kit). Simple to fit, came with O2 sensor dongles and everything you need. Took an afternoon to fit but straightforward.
They've worked out a map for SDRs fitted with Akra full systems and loaded it onto the PC. There's no downloading of maps to do, it's plug and play. Works perfectly. Runs beautifully and goes like holy fuck. Not worth spending any more on ignition modules or custom mapping. It's stupid quick as it is.
Sounds nice, but not offensively harsh. I will be putting one on my 1190 on the strength of it. Not least because there was dust in the stock airbox when I took it off..
If you have a gen 1 (or a gen 2) SDR, get rid of that shitty arirbox and get one of these that works.
What brand are they?I fitted these mirrors well pleased how well they work and just spin them up to clear the gap
😎 View attachment 46684
Significantly more oomph. Livelier everywhere. Throttle connection feels better too. More immediate. Not having to dig as deep to make things happen. Fatter in the mid-range than it was before, so much nicer to ride and easier to loft the wheel over the bumps. Goes headless above 7K. I think the power curve still slows a little at around 5K but it doesn't dip like it did before and feels much gutsier. I can launch out of bends now between 5-6K with the front wheel skipping, so not much wrong with it. Some ignition work would probably plump that out as well but it's minimal and doesn't warrant spending another £400 on a custom map or a PC ignition module.Stunning bit of kit by the looks of it. More oomph?
Do those frame rubbers that tank rest on need spinning back round?
What happened to your rally career?1290 is sold and new 350 excf will be here next week. 690 is being converted to Supermoto
They spin round like yours appear to of done, the tank then has play in it, which in turn plays havoc with the radiator mounts, which then causes the rad to split at the top rad mounts. Especially if you pull lots of wheelies. Straight up, I read it on Facebook.What's wrong with the tank rubbers?
