Spring
Thanks for the reply.
Not knowing much about springs, would this be suitable for my weight (14.5 - 15 stone in my birthday suit)?
The standard 88-250 White one on the bike is wound right down on the collar to give me correct static and riding sags. The seat height is (I think) pushed up as a result, which I also want to minimise. I was told the 92-250 was the one for me - is your one going to do the same job and be right for my weight?
So many questions but I might as well get it right!
If it's the same size/strength as the aforementioned - I'll go for it.
If you can answer the above (or anyone else knows) I can commit to buy it.
Mike
Hi Brompton
I spoke to ktech about the ratings. The first number is the inside dimension of the spring, the second is the length and the last one is the rating in n per mm
That makes your spring a very heavy one (like suitable for 19 stone or thereabouts) according to them.
Many thanks for the offer though.
Mike
