1 - 11 of 11 Posts
Hello.
Anyone got experience with this insert? Would like to know your opinion
Thank you
Did you read the Rust E-mag write-up?
Google 'Rust' magazine mate
I can't remember which issue it was
good article,worth reading...
Reactions: alex186
Why doesn’t anyone remember what they said in the article?
On this basis it sounds like a case of avoiding them and sticking to spring and oil🤷‍♂️
I'm looking forward to AER forks
you dont have to choose the wrong springs anymore...
AER cones minus cone mid valve?
Latest AER/XACT forks are decent, ridden a couple of ‘21> SX’s. Good out the box, hold up well.
Are they cone valves without a cone valve? Surely not? That would make them an AER version of 6500s. They probably share a lot of CV parts though other than the actual cone section itself.
Wow! Even more confusing!!!!
It appears the 7500s are for 50-65cc bikes. Open cartridge design but using a cone valve in the damper rod. External pre load adjuster same as true big boy CV or 6500s. I can’t see anything that suggests these are AER in any way shape or form? They are a mini ripper fork.
I wonder why they don’t make a full size OC fork with the cone valve?
Good point… I thought that could be the XPLOR/XACT difference but the one thing I took from all that confusion, was that was just branding mostly.
1 - 11 of 11 Posts
