1 - 4 of 4 Posts
X-Bushing
Has anyone tried these ?,I fancy one to lower my sons 09 sx250 at the rear.
He cannot get both feet on the ground at once,If I use one of these with a lower seat then I should see around a 2 inch reduction in height.
Looks a good idea as i,m only 5'5" BUT there is no way i,m taking 2mm off the Pds mount as it is,nt that substantial to start with and a swingarm is £400+!
I,ll manage as i am with mine!
It appears you can have 1/4 or 3/8 or 7/8 inch reduction in height,so I presume if you did not want to remove any metal then you the lowest you could drop the rear is 3/8ths .
Home Page
Fit a shock off an 06 or earlier bike, will lower the height nicely :)
1 - 4 of 4 Posts
