hi, just been offered one of these xc 400 at £5000 for a 2010 brand new on the road plus taxed,
just like to ask are these any good for green laning? and wots the difference between the xc and exc?
thanks nigie 250
nige
I have a 200xc road reg that i use for green laning.
I think the XC has a close ratio gearbox, and closed cartridge forks, were as the EXC doesnt.
The XC also does not have a stop light or horn or the option for one unless you change the loom(which isnt a major problem).
Nor does it have a headlight as standard, but the XC loom has headlight and Tail light plugs, so its just a case of getting a EXC headlight and connecting it.
Hope this helps.
Hi,
I think you mean a XCW (wide), as KTM stopped making 4 stroke XC models in 2009.
The XCW is pretty much the same as a uk EXC except it migh not have lights, clocks (some do)
The 400 would be ideal for green laning.
Alex
Check out Drysdales, Fowlers, Gear4
