2004 KTM200 exc gearbox oil.
1 reading
13K views 12 replies 7 participants last post by  Rad
Hi. Totally new to enduro bikes. Had road bikes for years. Just wanting to change the gearbox oil on my bike. Had the clutch slave cylinder off and it was a bit milky the oil I could see. Want to change it to see what it is like and then know I've got the correct oil level. My manual says 10/40 or 90sae. Anyone know what it should be for a 2004 model? I take it there is no oil level hole. You just have to measure it?
Thanks.
#6 ·
Right so there is a level plug but don't use it and you can use either at for engine oil? Reason I was asking about a level plug is it looks like it is leaking a small amount on the output shaft. Just wanted to monitor how much was leaking. Although it is working well as an auto lube for the chain.
Thanks.
#10 ·
my 200 leaked from the output shaft.......not from the seal, but from the inside of the spacer, there is an o-ring behind the spacer, that gets pushed down by the circlip and sprocket. You can get an after market kit with a slighty thicker o-ring and a slightly thicker circlip. this was the best fix I found for the leaky shaft.
