exc headlight upgrade
38K views 35 replies 13 participants last post by  Pingman
Are there any quick , cheap ways of upgrading the headlight on my 2010 exc 250 six days? Ive seen uprated stators from trail tech but not up for paying the money. Are the little led lights that adventure spec sell any good ?
#3 ·
Upgrading the headlight is tricky as you're limited by the standard lowish powered AC system. There are better lights but it's not going to be lots better. Something worth trying is run dipped beam from the tail light wire and leave main beam as it is, that means both headlight bulbs are on in the high beam position. The down side is that at low revs on high beam thing will go pretty dim.
The DC system on the bike is pretty limited but it will run a couple of bar mounted LED lights assuming you still have the capacitor fitted (run the lights from the horn +ve wire, through a switch).
An option is to float the earth, use a Trail Tech Regulator (for AC) or Reg/rect and battery for DC - you'll get 50/60 watts I'd have thought, not enough for big HID but enough for a decent halogen headlight (X2) or more powerful bulbs. HID and LED need a DC system (except LED enduro rear lights, they have a basic form of rectifier built in).
For big lighting the only practical option is a Trail Tech Stator and reg/rect.
For any kind of night time off-road riding a decent helmet light is essential. Without it you can't see over drops, round corners or find your way back to the track when you ride off it.
#7 ·
If you have a Freeride then it'd make sense to do the first ride with the HID on easy trails - if the HID drains the battery you'll be bump starting. It should all work fine though. A word of caution with HID - if the battery is draining they don't go dim - they just switch off (the actual voltage will vary depending on bulb).
For the OP with the EXC - unless you have a battery ( I've assumed you don't on the '10 6 Days EXC), HID will literally be a non starter.
#8 ·
Do you recommend one specifically? I have a small one already but would not say its up to the task of illuminating ahead when riding
I did not know know they did this, pleased you let me know!
I am fitting to a 250 EXC-F (has battery) that I use to ride unsurfaced byways (greenlanes)
#13 ·
I use one of these; 121345977805
They come with a battery buy mine packed in after a while, overcharged i think so I bought one of these; 151223134430 slightly hight amp hour batter so last's that bit longer. Use one for walking the dog at night too, easily lights over a football pitch sized field so a good view.
#28 ·
Go with the halogen ba20d bulb upgrade and then leave the headlight alone. The lens is plastic so you won't get any better light from it especially as the reflector is no better than silver paint on plastic. If you try and upgrade the power it will all just melt and you'll get shite inside the lamp housing that will either blow the bulb or just stop the lens and reflector doing their job.
HID is just not worth the cost when you can fit cheap LED lamps that produce silly amounts of light for the power they use and heat they produce. IMHO HID has been bypassed by LED now.
As with any light, its effectiveness is a combination of lens and reflector quality. Go for the larger lenses and check if the lens is a spot or flood pattern. It doesn't matter if the manufacturer promises 10 zillion lumens if the lens is scabby plastic and the size of a postage stamp. You might as well use a candle in a jamjar.
Yes, the Vision X lamps are excellent and very well made. I have used a pair, 1 flood 1 spot, for about 5 years now. Unfortunatley they have not come down in price in line with LEDs in general but you get what you pay for.
