Fork spring identification
2 reading
8.6K views 10 replies 7 participants last post by  Nokkaz
Evening all, nice simple one here. I have some fork springs that were taken out after suspension work. They have no markings/numbers on them. Am I right in thinking they are standard. Want rid but need to know what I am advertising. Cheers all.
#3 ·
I didn’t buy either bike new, but pretty sure they were standard. One bike was made softer, one was made harder but that still doesn’t tell me what they are.
Easy way to check.
Get a piece of pipe the spring fits inside. Seal the lower end. Fill with oil right to the brim. Slowly place the spring in and catch any displaced oil. Measure the displaced oil. 38ml is 3.8nm spring. 42ml is a 4.2nm spring. 46ml is a 4.6nm spring and so on.
A slick as you like method of checking unknown springs. Stops them rusting to.
#6 ·
can't see that working with the different length springs etc
#9 ·
You’ll need a spring that you know for defo what the NM is and is the same length with the same number coils to compare to the unknown spring. Measure the coil thickness with a caliper, if one spring coil has a 5.1mm thickness and you know that to be a 4.6nm spring then a 5.5mm measured coil will almost certainly be a 4.8nm spring. The difference in thickness between weights of springs is a fraction of a mm.
Maybe I will just bin them. Really can’t be arsed with it, can’t believe they are worth much anyway.
