Gearing EXC 350 F 2024
2 reading
7.6K views 7 replies 5 participants last post by  steveman
The day before yesterday I picked up a 2024 EXC 350 F SixDays from Upper Austria, already converted by the dealer for off-road use, so all the street legal stuff is gone. I noticed that KTM has fitted a noticeably small rear sprocket with only 48 teeth. As far as I can remember they used to have 50 or more teeth.
Does anyone know why? Has the gear ratio been changed? I haven't ridden it yet.
#2 ·
My 2016 200 came with a 45 rear sprocket Steve. Totally insane.
My guess is they do this for road users and potentially money saving as less sprocket material.
Get it changed for normal gearing and enjoy it as it should be.
#3 ·
Nope, it is not the road use sprocket, it is definitely the one for off road use. Dealer confirmed they all have a 48 instead of the 50 (or was it 51?).
I know that Betas have a 48 as standard and older non-KTM-GasGas too. But I am still very surprised. Just rode it in first, second and third and it felt pretty good. Need to test that back to back with an older 350.
Looking at the manuals from 2020 to 2024 the 2020 had 14/52, the 2024 now has a lower primary drive and a higher 1st gear. Overall it might all be about the same, I've always thought that the 2020 could have done with a lower primary drive to give a better choice of sprocket ratios without dropping to 13T front. I put a 14/48t on our bikes for a trip to Portugal last month at least one climb neaded a lower first gear ratio but the added road speed made it more suited for open sandy tracks that we like.
#6 · (Edited)
Funny enough, that the owners manual says it should be 13/46. The gear box of the 2024 compared to 2018 is completely different. Primary ratio and all gears of the 24 are significantly shorter different and that is the reason for the longer secondary ratio. I entered the data in my gear data excel sheet and that shows a very clear picture.... At 10500 rpm, the theoretical speeds in all gears but the 6th are lower although the sprocket of the 24 is smaller. In 6th gear the speed is the same.
Thank you all!
Reactions: Snaf
