8,041 - 8,060 of 15,035 Posts
As you will know its a twat removing the rear wheel on motos due to the caliper in the way.....so cut a space in the slider so you can remove the caliper 1st then nice and easy remove the rear wheel, on the smr it's a pain
[/URL][/IMG]
[/URL][/IMG]
dont wanna fuck the carbon matrix either !
Wossner Piston, chain, tensioner, gaskets, gear shift shaft cause mine is scored at the seal and leaking, 4x kibblewhite valves. And various new nuts etc. And a chain breaker/riveter.
Going to try and take pics through the whole process of the rebuild.
what was the cost of the rebuild kit pal ?
450 for everything. Would have been 60 cheaper without the gear change shaft. Forgot the 2 cam bearings too.
Currently in the middle of the rebuild now.
Not just today but over the last week:
Spankers 250 Exc Six days
Fitted map switch
Re-jetted
Fitted proper hand guards
Changed tyres
Fitted mousses
Greased the dry wheel bearings
Fitted new springs front and back
And all this before I've swung a leg over it - "Ready to Race"....
Given the weather forecast it'll probably be a few months till I can ride it properly!
Oh and the black finish on the rims isn't anodising it's a really cheap black paint which now has a chunk missing on every point I used a lever.. hmm.
Otherwise, can't wait to get out on it.
DCR did mine ÂŁ600 for rebuild........piston, rod, mains, camchain, tensioner and check valves etc 3 day turnaround, very good service
Thats very cheap for rod included buddy.
Got a good deal there especially to do the con rod and main bearings.
But 150 of mine was just the kibblewhite valves got busted on import tax from america. So with out valves and gear shaft would be 240? Ktm bits are nice and cheap I think.
Ive got mine all in bits now main bearings feel good and big end has zero play. Taken lots of pics so may do a write up.
SMR, put new rear tyre on, changed oil and filter, cleaned oil screen and give it a good clean
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Reactions: twiggy
cheers pal, i needed some space, so thought fuck it and built a workshop.....got storage space above for all tyres and stuff
stop it i can't take anymore,it just gets better.Not to mention the 2 pukka bikes housed inside as well.
A tad jealous slugger top job.
Reactions: slugger
